Y-pipe question...
SHOhopefull
Boaz,Ala
Ok, I'm trying to make a list of all that needs to be done to my car. It needs an equal-length Y on it(currently stock), and my question is: Since it's Fidanzza equipped, would it be better to go for the catted equal-length Y?
It already is a bit slow on the bottom end( but I think it needs a new MAF too LOL) So would a catless be too much of a drop in low end?
frosho
WOLFMAN
Tyngsboro, MA
I say go catted... I did. I didn't want to deal with the smell of a cat-less pipe, or the rasp, or the supposedly weaker low end, so I got a SHO Source catted equal-length pipe from a forum member.
I don't see why the Fidanza should factor into your decision though. Are you just worried about how much torque you have on-hand when you're letting out the clutch?
SHOhopefull
Boaz,Ala
No, it already has the Fidanzza installed, it just feels a little weak in the lower end...I wasn't wanting to make the problem worse, having heard that a catless Y would drop the lower end a bit.
frosho
WOLFMAN
Tyngsboro, MA
Gotcha. I've never driven a cat-less SHO, so I can't really chime in on that point... FWIW I have a Fidanza along with the equal-length pipe and like them both very much.
twitchblade
KC MO
also keep in mind that if you have to do smog test for inspection in your area, cats are required.
zak
east of Hartford
Every cat-less SHO I've ever driven was pretty weak below 2.2 krpm or so.
