The Shosource Y-pipe has a lot of advantages over anything else.
When I got mine, they gave me a better price on shipping than is advertised, so inquire about that before you throw in the towel.
The big difference is the Shosource unit is delivered in sections that are fitted to clamp together, so the shipping box is smaller, and when it comes time to install, is 100 times easier. Each section goes in individually, so it becomes a one man job.
I did mine on my driveway by myself.
I too, moaned and groaned about the price, but I quickly had a change of heart. The Shosource system is stainless steel, and I don't know for sure about the others.
The pieces go together so precisely that you don't need to clamp them right away. If you still have the brutal dynomometer e-test, I would recommend not clamping them. Mine went through the test the first year, but 2 years later they failed. I never changed the converters as our area went to the sniffer at 2 rpm zone and it passes that with ease.
With the standard preformed units, you have trouble drawing the down pipes up to the engine manifolds, and you need a guy (or a whole lot of jackstands) to hold that far end up in the air while you aim-up the front ****** bolt holes to the manifolds.
