Dasfinc
Cam sensor controls fuel. If it is running without cam signal (yes people it can/will run) it will be pig rich. If it is rich, ecspecially for long periods of time, the cats will be ruined. So keep that in mind. What I would start with as of now is (without being able to put my hands on the car)
1. Cam sensor
2. Loosen y-pipe at manifold and see if car has more power
3. IAC - or check for vacuum leaks (for your Idle problem)
I take it that removing the thread sealant from the knock sensor cured that for you?
- James
I just realized you were that nice fella at Dyno day!
You just said word for word what I was thinking basically
I JUST got off the phone with Kim like an hour ago and told her "I suspect the cam sensor has been ****** since we got the car, and its been running rich since *hence the bad gas mileage* I suspect recently *the past 3 months* its been getting progressively worse as the cats are probably being destroyed, so I ordered a new cam sensor online *$28 at autozone.com* and we will go to pauls tomorrow to gut the cats out" (buddy of ours who can weld)
I have a full spare manifold with another IAC valve, and yet ANOTHER in my closet *dont ask* so I will check out the other 2 to see if that helps that issue, but it obviously is a VERY small concern of mine compared to her getting 8mpg and being slower than my focus...
I couldn't get a hold of the right socket to pull that damn sensor this weekend, so by the time I got back to the new sensor I had no way to get it back out, but after cleaning off that ground in the valley, and protecting the ground wire again it seems to have gotten rid of that code.
did you check to see if the SPOUT jumper is present?
no CLUE what that is I'm afraid, Pics?
I forgot to take into mind that motors were swapped. Pinched/loose wires anywhere by chance?
And it was in an accident, Lol.
No, no pinched wires, lots of broken connectors since probably every connector on the entire engine harness is broken but everything seems to be holding just fine, and a few 'relocated' grounds, but nothing crippling that I could find.
