wont start
shoff89
upper marlboro,md
recently my car has been stutering real bad and cuttin off from time to time. This time it didnt restart. I had to spray ether up the intake to start it. What is the possible problem?
windsormw
stretch nuts
windsor , ontario
wow ............. ethier is never an option ( for me anyways )
etheir can do a ton of damage to a gas powered motor , we use to use it on tractors ( deisel ) just to get em to fire .
first off is ur CEL on , and if so , run the codes . does the idle go up and down like a ****** pants on pay day ? when it ran , did it surge @ stedy RPM ?
More info is needed , these SHO guys and gals will help u out ( thier better than me )
But from what i know GET RID OF THE ETHIER
shoff89
upper marlboro,md
Well when I first start the car it surges then it calms after awhile. Next the cel comes on five minutes after I start drivin and intermitanly goes on and off. I ran the codes and they were the usual,95,56,59,66,61
windsormw
stretch nuts
windsor , ontario
u got a few MAF codes there , i would recomened that u take out that MAF sensor and clean it with a carb cleaner spray and some q-tips ( be careful though they are very delicate )
fuel pump codes , i have that code too . i hope that it is just a simple sensor cleanin as well , but more than likley a new pump will solve most if not all u fuel pump codes , The IAB valve could need some inspection ( shotimes has the procedure )
My sho was failing the e-test like crazy & the car surged @ any rpm , I cleaned the IAB & MAF , changed the oil and pow . Car runs great .........i was amazed @ what a little dirt can do to an engines performance
good luck :thumb:
