40BelowSummer
Immediately losing fuel pressure after fuel pump prime - new fpr
Ive just about got my supercharged SHO running after 2 weeks. It got a new SHONut (mallory) adj. fuel pressure regulator/suspension/brakes/wheels/tires and other non-related goodies.
The car has ZERO fuel pressure after about 2 seconds when the ignition is turned on. It goes up to about 20 very briefly them immediately back to zero. The fuel pump primes everytime.
The fuel pump is priming and pushing fuel into the fuel rails (as indicated by the gauge) then immediately back into the fuel tank (which I can hear I believe). Is this because of a bad return check valve or perhaps my new Adjustable FPR is somehow allowing all fuel into the tank Or is there a check valve on my fuel pump that is bad making me have to replace the whole pump?
Thanks!
I have an aftermarket fuel pump (not sure what size)
EDIT: When I hooked up jumper cables to the car I left the ignition on and was cleaning the connection on the car giving the jump. In the process I prob closed the circuit about 50 times which made the fuel pump prime alot. At one point I heard a faint boom or pop noise which I think came from the fuel tank. But the fuel pump still works fine. Did I blow a line or check valve perhaps?
Thanks!
