Won't Start After Motor Swap
SHO Continental
Moderator
Northridge, Cali
This is on a '91, will not start, has fuel/spark/air.
Recently swapped the motor from my totaled Mocha '91+ into my black '91. Previously the black car had been picked at, leaving the insides of the motor exposed so I opted to just swap it out. In addition to the motor I had to replace the headlight harness as rats chew through it, although I don't think that had any effect on this. After the swap the fuel pump on this car didn't work, not sure if it ever worked before. Swapped in the tank/pump from the Plus, had a voltage drop at the plug for the pump ~10.1 volts which led to the pump not running. Hardwired the pump to a switch, pump now runs. Car has spark, fuel pressure is 35 cranking, 40 with key on. Won't start.
Any ideas? Possibly some plugs on the harness crossed?
Mr Anonymous
Tire Wall
There's a lead coming off the positive battery cable that attaches to a "Christmas Tree" connector behind the pass. headlight. It's very common to miss that connector on '91s and will cause the exact symptoms you're seeing.
