SHOed_up
I somehow managed to run into two problems at the same time today, lucky me.
94 mtx w/ 80mm maf and LPM, it was about 90 degrees today as well. Not sure if any of that is relevant, but it can't hurt to mention.
I went down to the BMV to renew my license today, about a 20min drive. The car started up fine, ran like it normally does on the way down. Started fine, and ran normally coming home as well...until I stopped to get some chinese for lunch. Maybe a 5min wait before I got back in the car, which is when I discovered it wouldn't crank over. I popped the hood, fiddled with the battery cables a bit, making sure they were secure and making good contact, which they seemed to be. The lights/radio/windows all worked as well, so I tried cranking it again, and still nothing happened.
Well, the chinese place is just down the street from my place, so I figured I'd try to get the SHO home at least before I started troubleshooting things. I gave it a good push, slipped it into first and popped the clutch and it started up. I got as far as pulling up to the stop sign at the end of the parking lot...it stalled when I came to a stop. Luckily things weren't too busy, so I had another go at a push start, and this time I made sure to watch the tach, it tried to stall whenever I slowed down enough for it to drop down from it's 1500rpm "rolling idle", so I had to nurse the throttle for the two stops I had to make on my way home. When I got in my parking space I went ahead and stopped nursing the throttle manually, and let it try to idle on its own. It dropped to 500rpm then bounced back to 1000-1100rpm twice before it finally died.
Either one of these problems on their own would be merely annoying, both of them happening at the exact same time has me baffled.
