Wiring most outer light to always ON position - Gen II
RI-SHO
B to the BANNED
Pawt., RI
I can't think of the name right now but how would I go about making the most outer lights stay always ON instead of only going on to whichever side I have the turnsignal on towards to.
I prefer for it not to blink and be on as just another brighter parking light but if my only option is to have it blink with the inner turnsignal light then I would do that too. Also i'd rather be able to wire so it has its own power source and isn't making another light dimmer because I just ran a jumper to it(only way I can think of right now).
So can any electronics techies help me out here?
SHO92
Upper Freehold, NJ
Are you talking about having the white cornering light be on all the time that the parking lights are on? If thats what you want to do you could cut the power wire and run a new one to the same place that the parking light is powered from, or you could wire it into the fog light switch after doing the fog light mod. Doing that would make it so they lights were always on when the fog lights were on, and it would be controlled by the factory switch. Basically all you need to do is power them off of the same circut as the parking lamps.
I wired my front clear sidemarkers into the backup lamps and the turn signals on the '97.
To always have them on wire them to the parking lamps.
Slo-Sho
It wasn't me!
Crossroads, CNY
Or...if you wanted to get real trick...you could get a dual filament bulb in there and have the it so the parking filament lights up with the parking lights and the brake/turn filament lights up as the cornering light. Same idea used in Maximas (not sure what years).
