Wiring Harness
atvlady
Pulaski
I am in need of a wiring harness that goes to the engine. I have a 3.2 v6 95 SHO DOHC. We went on vacation for a month and the rats had a feast! The wires are chewed all the way to the plug-in so there is no way we can fix it. Gonna need a new one :(
deercrusher
never running!
PA
This is posted in the wrong section FYI - it would receive better response in the Wanted to Buy section. Anyway PM me I have an engine wiring harness - it's out of a 93 ATX 3.2. They are compatible.
fyi, the 93 and 95 harnesses are not the same.
deercrusher
never running!
PA
????? what's different? You really have me stumped as to what would be different about the harness - same motor/ same trans only difference between her car and my old 93 would have been the ECU right? mine had a h3z2 and she'd have the d4u1.
sorry, wrong answer. ask me how I know.....
the 93 has R12 a/c refrigerant, while the 94+ have R134a. the R134a system has a high pressure cutout switch that is not present on earlier cars, and there is wiring for that.
the 93 has different wiring to the wiper motor - 2 connectors rather than 1.
the 95 has different wiring to the rear abs sensors - at the right rear of the engine compartment has a different size connector than the earlier cars.
iirc, there is one other difference that doesn't come to mind at this moment.
depending on which portion of the under-hood wiring the op needs, one or more of these will be in play, and will lead to significant frustration, especially if you don't play this game regularly.
