Windshield washer pump fuse location
Tino157
Hello everyone...new here...2011 sho...I was wondering where the windshield washer pump fuse is located...pump stopped wirking...I hear the pump buzzing though....thank you....
SHOrod
Torrie Tuned
Cedar Rapids, IA
If the pump is buzzing the fuse should still be fine. Buzzing would suggest power is getting to it, but it's probably stalled for some reason (failed pump motor or obstruction).
Are you able to access the pump to pull the hose off the output to see if any fluid comes out?
-Rod
