Windshield cleaner.
Grouchy
My 14 SHO decided to stop spraying windshields water. Every other part of the wiping system works great still but this is aggravating with all the bugs. Container is full. When u pull it wipers go but no spray. Anyone else have this. I can't find the motor.
Thanks
Sent from my SCH-I545 using Tapatalk
bpd1151
Lurking Around
SHOcago 'Burbs
Very common for the windshield washer pump to outright fail.
Not an expensive part by any stretch (I'd like to say last time I did it, was around $35).
Easy to R&R as well. It is literally snapped into two tabs that are formed as part of the reservoir itself. Outer most edge, on psgr side.
Lostneye
NY
Mine has failed as well. If you have someone press the washer button and then tap on the pump you may get it to work slightly to verify that is the issue. It most likely that is your problem.
StealBlueSho
NA
I think you can just remove the the inner fender plastic splash shield on the passenger to get to it. Advance auto has one for $25 I believe...
StealBlueSho
NA
You will need a Philips, Flathead, and an 8mm socket.
Hebes10
Pittsburgh, PA
This is what happens when you don't use the Motorcraft Specialty Blue windshield washer fluid. :D
I bought RainX bug remover fluid for my wife's 2014 Escape and it clogged the screen before the pump. Manufacturer thinks the fluid froze at one point (in the Advance Auto warehouse) and the silicone separated out. They suggested spraying water in the fluid reservoir to try to loosen it up. I still don't have it figured out yet. Now I use a coffee filter and strain washer fluid before putting in my SHO!
