Window won't roll up? Possible fix.
Jrodm12
Wa State
Hey after many hours of trying to get my passenger side window working as i could roll it down no prob but rolling it up was the prob. The motor is fine and strong on the window. I took off the side panel for the passenger door and everything looked fine. Switch was fine I couldn't find out what was wrong. Well after many curse words I found the FIX. Well for me at least. I opened the driver side door half way and the master control for the passenger door will work EVERY time when i open the door half way.... IDK if it is a short but now i can work it just not whille driving down the road. If anyone else is having similar probs try opening the door in differnt possitions. Also anyone know why this would be like that I find it pretty wierd like a possed car or something.:) Laterz.
Ishodu
Just sounds like you have a short in the power wire in the loom going into the door from the body. You will have to take it apart and find it. That will be the only real fix.
StLSHO
Saint Louis, MO
Another thought...
Halfway? Or just wide enough for the interior lights to come on? (I don't know how that setup works, but when the doors open, at least one circuit is completed...Just a thought.)
Good luck.
