window leaking??
tps761
massachusetts
hey i have a leak from the window frame if you guys knows what i'm talking about. its leaking on both sides which is strange. what could this be the sun roof drains clogged? because it seems like it is comming from the inside of the frame. anybody know whats causing this?
lowc
aka vapah lock
Quincy, massachusettes
best thing to do is blow some compresed air through the drains just to be sure and if it still leaks i would check the seal around the windshield its self
tps761
massachusetts
thats what i was thinking. its def not the windshield itself because i had giant glass out to my house twice to fix the leak. (i origionally thought it was the windshield because i had a crack in it so i called giant glass and they came to replaced the windshield. thats when i first noticed the leak) so they assured me that its not due to the windshield seal itself. are there drain holes somewhere around the sun roof?
NoSlo
SHO Owner
Portland, OR
If you don't want to pull a complete set of rubber from a wrecking yard to replace the weatherstripping, you could do what I did to fix a leak - adjust the door latch. It takes a big torx socket (think T-50 or something), you loosen the latch receiver post in the door jamb and tighten it back up after moving it down and in a little bit (and making sure your door still matches up to the post and latches firmly. This will hold the door more firmly against the weatherstripping.
