Is there One fuse for all four? If not, Which number fuse is the driverside rear?
Window will not go up or down using either door control. Took panel off and now I dont know what to do. If the front button has carbon buildup will the rear button not work too?
The motor looks clean, I took it apart. I wanted to check the points to see if there was carbon build up. But the stoopid Window lock button has some weird spring thingy that wont let me take it completely apart! thanks 4 your help
