The physical bolting dimensions are the same, but the crossover tube and rubber connectors have different configurations. This is not a problem, rather, more of a running production change. However, you will have to block the unused exhaust gas recirc port on the driver side rear corner. The 3.0L engines do not have this port drilled out. The 3.2L has a metal tube bolted to it.
Scott
1991, 252K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
Class II hitch, Silver award at the SHOklahoma Car Show
[This message has been edited by sdpatt (edited 11-24-2001).]
