Will 92 MTX Radiator fit in 94 ATX??
azmattaz06
Tucson
Just wondering cause my overheating problem's continue and i already changed the ECT sensor and now plan b is to change the whole radiator i have a 92 MTX for part's pretty much and it ran pretty cool all the time so im gonna just swap them if they fit.. if anyone know's please let me know thanks
Mr Anonymous
Tire Wall
Yes, but...
Check to see if the '92 radiator has the fittings for the ATX tranny cooler lines. That would be the only concern.
USHOMEISHOU
Troublemaker
New Mexico
If I'm not mistaken the only difference is the fan/fan's the radiator is the same.
I think:shrug:
Yes, but...
^^^what he said:thumb:
azmattaz06
Tucson
I'll check that.. but just wondering could it still b clogged or rusted if the antifreeze is really green with no sign of rust or anything? and another thing is the ECT sensor is not my problem i checked it with a really expensive scanner and it showed that it's working so im guessing radiator..
Phoenix
SHOHOLIC
QC , Canada
How about the thermostat?
When you play guessing games its better to go with the easiest/cheapest to start with.
azmattaz06
Tucson
Checked the thermostat and it's opening up so what now? i've narrowed down that the ECT sensor is working,fan's coming on,thermostat is working.. Now what? still overheating is slow traffic or at long drive thru's but cool's down when driving speed's... If the radiator is next how could i find out for sure that it's clogged? and does anyone know for sure if one from a 92 MTX will fit my 94ATX?
Phoenix
SHOHOLIC
QC , Canada
Bad/old coolant can also do that , if not go with the rad. As for fitment MTX/ATX, Mr.A nailed it.
azmattaz06
Tucson
so nobody know's if it'll fit? i can't tell by looking honestly so if anyone know's please let me know im really tired of my car heating up.. thanks
yzstud
< my kawi
Minnesnowta
as already stated twice in this thread, YES, the radiator will fit
the mtx radiator should have caps where the atx cooler fittings go,
just pop them off and swap the fittings off the atx rad onto the mtx rad
Storm-Chaser
Shit Louis
Let me guess . . . .
. . . . you still haven't had the TEMP gauge checked or validated it is overheating with a mechanical Temperature gauge or infrared thermometer, when you think it is overheating . . . .
:slap:
azmattaz06
Tucson
i had everything electrical checked that showed all the volt's the sensors were getting and how much they needed to be gettign to be working and all was fine.. thats why the radiator is my last choice
TimboSHO
Intermediate
Wyoming, MI
It will fit, but if it's the original in your 92, it won't have the fittings for the trans cooler..... just run an aftermarket cooler if that's the case.....
azmattaz06 said:
Would a coolent pressure tester help find out if my radiator is clogged?
No. But if you take off the upper and lower hoses and try to run water or high pressure air through it, you may have a better idea. Is the cooling fan coming on at the right time? Are both fans working? Is coolant flowing through the heater core (do you get heat out of the vents?) Is your water pump pumping? Are all of the fins on your A/C condenser flattened out, not allowing any air to get to the radiator? Are you SURE the t-stat is opening? Have your checked the boiling/freezing point of your coolant (cheap tool at autozone)? Are both temp. sensors working correctly? There are many different reasons a car could overheat, just stating a few....
RAYJAY
WHO ME ?
UNION DALE PA
How can i tell if my water pump is going out or not pumping enough?
how many miles on the car ???? and did you ever do a front 60k on the car???
with the cap off do you see water flow
also did you pull the belt off and spin the water pump see if there any play in it
Jeff
peganit
Michigan
It's the littlle things
I put a base Taurus radiator in my 94 SHO ATX, and everything was identical EXCEPT! the tranny coolant fittings. The base Taurus used smaller fittings.
I modified mine to use the bigger SHO fittings.
Brett
SHOs before HOs
Minnesnowta
Ive had this exact problem for a long while and am curious to what fixes yours. Only overheats in stop and go traffic and in drive through's. Freeway or open driving and its fine. Replaced ECT, thermostat etc. etc. just not the radiator yet. Hope you find the solution to the problem your looking for.
azmattaz06
Tucson
Me to man i can afford a Radiator right now so im not sure what to do.. If i take the cap off the water moves and theres flow i've changed my ECT Sensor, Thermostat is opening good... Now what? im guess radiator flush won't fix the problem also the water is green and clear no rust or dirty stuff at all.. Any Suggestions?
RAYJAY
WHO ME ?
UNION DALE PA
how many mile on the car ???? and was the front 60k ever done ???
also try to blow out the radiator and air conditioning condenser out with low pressure air (25 to 35 lb ),
and are both fan running ? when you do the code test
Jeff
azmattaz06
Tucson
Car has 135,000 miles.. i believe the 60K was done but i've only owned the car for a few months now.. when the car is started with the cap open the water goes down and if you give the car some gas the water will go down everytime but come back up.. this mean the pump is working fine right? and yes i believe both fan's are running when the test is done.. i don't quite understand what you said to do about the radiator and air conditioning condenser..
ribeye2065
