Wil 3.0 heads fit a 3.2?
ml98188
Seattle
Have a 94 ATX that I'm sloooowly modifying. Found a guy locally that
has heads from a '90 complete with cams that he wants to get rid of.
Thought they might make a good base for rebuild and modify but don't
know if they're interchangable with 3.2?
Thanks in advance for comments.
SonicRiot
Handbanana!
CT
3.0 heads fit the 3.2 block. Use the 3.2 head gaskets. It's a nice mod, actually. Do a search for more info.
Or I'm sure others will chime in. Cam the thing while you're at it.
Bizzy
Keep in mind that 3.2 head gaskets are EXPENSIVE. (Last time I checked anyway.) I'd make a list of things you want and the items required to make it happen before you tear anything apart. See if it fits your budget and if it does then collect all the parts you'll need prior to tearing it down. After that, make it happen. :thumb:
ml98188
Seattle
Sonic,
Thanks I'll go ahead and pick them up if the guy will answer my emails. .
Cams - definately- among other things (hee hee)
Bizzy-
That was kinda my thought.
Intake mods and Heads are about number 4 on my list and I'm only about halfway through number 2 (ATX Trans). In that this guy is virtually giving the heads away I thought I'd pick them up if they'd fit, then take my time and build them up as the opportunity ($$) presents itself.
SHOtimer
#2910
Santa Clarita, Ca
3.2 head gaskets are about $100 for a pair - which is around the same price as the 3.0 head gaskets......
However, you cannot use the 3.0 heads on a 3.2 ATX - the front 3.2 head has a unique mounting cast into the head so that the accessories will fit onto it. Swap the heads and your in for a car that won't go back together.
The only difference in the heads is that the 3.0 has different cams. People have switched and dyno'd the difference - came out to 1 hp, and that was with a MTX. Better off leaving well enough alone. Save up for a tranny rebuild.
Doug
ml98188
Seattle
Hmm - thanks for the info. Trying to keep this thing as stock looking a possible at first glane so maybe these aren't the way to go.
Just had the tranny rebuilt and am NOT happy with the results. Still suffering from slow shifts and it just doesn't like third gear at all. Half throttle yeilds a 2-4 shift with maybe a nod at third passing by. Taking it back next week.
Thanksagain for the info
93rev2sev
Hockeytown
Doug
For real? I'd like to see the dyno sheets...not because I'm challenging you...I would think its a flatter curve...especially helpful on the low end?
Bizzy
Really? Wow, it must have been awhile since I kept up with the latest news on those. Last time I checked they were in the neighborhood of $200, but like I said, it's been awhile. That's great news! :thumb:
SHOtimer
#2910
Santa Clarita, Ca
I just searched through my PM box - where the link was, it is gone. It was done by SLOSHO89 - Efren. He hasn't been around for about a year or so. He had an '89 that he did the 3.2 swap in, dyoned it with the 3.2 cams, then swapped them to the 3.0 cams.... It was a 1 hp difference.
Doug
SonicRiot
Handbanana!
CT
Doug
You're right, but I thought the cast could be ground down to clear the accessories. Hm. It's been a while since I've been under the hood of a 3.2 SHO.
SHOtimer
#2910
Santa Clarita, Ca
The 3.2 heads can be ground down to be used in a MTX application. Yes. However, he was inquiring about using 3.0 heads in an ATX application, which would not bolt up....because it would be lacking the necessary casting.
Doug
AREA 91
PA SHO SHOP
Area 91
Camshaft Info:
As a primer, here are the measured specs of the stock cams:
MTX Intake 0.348” Lift, 205° Duration @ 0.050”
MTX Exhaust 0.328” Lift, 201° Duration @ 0.050”
ATX Intake 0.328” Lift, 201° Duration @ 0.050”
ATX Exhaust 0.328” Lift, 201° Duration @ 0.050”
The ATX Intake chain ****** is also advanced 4 crankshaft degrees relative to the MTX cam. As the Intake chain ****** is what drives the Exhaust cam, this effectively advances the Exhaust cam in an engine with ATX cams by 4 crankshaft degrees, which also reduces the overlap by 4 crankshaft degrees. Compounded with less duration on the ATX intake lobe, there is substantially less overlap with the stock ATX cams. In total, there is 6 crankshaft degrees less overlap, 4° due to the advanced exhaust cam, and 2° due to 4° less intake duration (1/2 of the total duration difference).
IMHO the extra .028 of lift, and added duration should be worth more than 1HP. I thought I could see/feel a difference after I swapped 3.0 intake cams into a 95 ATX.
Shoaz
Studly dood
Scottsdale, AZ
So you're saying the additional lift of the MTX intake cam plus the associated retardation of the exhaust timing should be expected to make more than 1hp difference?
93rev2sev
Hockeytown
AREA 91 said:
Camshaft Info:
That's the best information about MTX cams in a 3.2 that I have seen yet. When I get home I might a question or 2 for you, Area91...if that's ok
SonicRiot
Handbanana!
CT
Doug
Gotcha!:thumb:
Sorry for the misinfo.:slap:
