wierd sound on downshift on mtx 3.0 sho
moobypets
mooby
quebec
as soon as i downshift from 4 to 3 i hear a loud click
or it whine and click
im unsure ill try and get a vid out off it
but this is startting to scare the **** out off me
could it be the axles ?
or some engine mount ?
even 2 i have the 2 shonut solid mount
moobypets
mooby
quebec
they are the original 300 000 mile plus axle
and last time all was checked bearing balljoint and all the rest as for the axle unsure it there a special way to check the axle ?
blownsho94
Pennsylvania
Is there grease all over the bottom of your whip? Or, oozing out of the CV boots? That is usually the first indicator of a problem.
lowc
aka vapah lock
Quincy, massachusettes
grab the axle(s) and give them a good wiggle up/down and side to side. there should be a little play you should be able to feel if there is an issue there
and what rpms are you down shifting at?
moobypets
mooby
quebec
welll if im running 130 ill donwshift in 4 and then in 3 when the rpm goes down a regular downshift
