Wierd electrical things
Cward
finder of parts
Big Lake, MN
Okay folks, need a little help here. My 92 is being weird. Was doing fine till I washed it Saturday afternoon. Took it through a touchless was,(didn't want to break the antenna as it is stuck up) Pull out of the wash EATC is dead and the airbag light is flashing. Hmmm. Got home, shut it off. Restart it everything is fine. Figured I just got something wet and it had to dry out. Fastforward to this morning. Hop in the car start it up okay. Back up, bang EATC goes out, airbag light starts flashing, radio starts acting funky. Flashes, music gets quiet and then goes back up. So I'm guessing it's a ground somewhere, or a bad signal switch as when I turn the hazards on the eatc and the cd player flash with the hazards. I did rain pretty hard last night but I doubt it's the problem. I can't figure out a ground for all these items though. Any suggestions?? I came home early from work to try and figure this out and the wife needed her van.LOL HELP!
Cward
finder of parts
Big Lake, MN
Well, I went down and did dome poking around. Pulled down the fuse box and started checking fuses. There was 3 of them that were loose! I pushed them all back in and the problem seems to be remedied. The EATC stayed through about 5 miles of driving so, I'm hoping. I know the one fuse was for the EATC too.
Cward
finder of parts
Big Lake, MN
Well I was wrong. It's still doing it for the last couple days. I'm really confused and ****** off! Yesterday at one point I closed the moonroof and the radio turned off and on! Somebody help,PLEASE!
SHO#7
Cincinnati
Check your connections on the battery, make sure they are tight and clean. Then check the battery itself.
Mike
