Wierd Door Ajar problem
crazy_canadian
Rattle-Mobile
Quebec
Hi,
Since this afternoon, for the first time, the door ajar light stays ON, but the interior lamps are OFF :oogle: . The lights turns on when I open everydoor execpt the rear passenger door.
Is this a bad switch ?
Ace
Manning Hater!!
Norfolk Mass.
sounds like you need a jamb switch for the rear passenger door and also a door ajar switch for one of the front door handles...to avoid any confusion these switches are NOT the same...the door ajar switch bolts to the door handle inside the door and the jamb switch screws into the pillar and makes contact with the door...
crazy_canadian
Rattle-Mobile
Quebec
so the jamb switch turn on the int. lights and the other, the door ajar light in the cluster ?
crazy_canadian
Rattle-Mobile
Quebec
so,
To get to the door ajar switch, I need to take the door panel off ? its on the handle itself or on the lock mecanism ?
btw, its spelled Tabarnak :thumb:
Ishodu
Try a search on the door ajar, You more than likely don't need to get a new one just need to free that one up.
ohfosho
ontario SHOwner
ontario, canada
lol
anyways, the door ajar switch is in the latch mechanism...i replaced the latch and actuator assembly in my 93 atx passenger front door, and because i got the part from a regular taurus, it didnt have anywhere for one lonely wire to connect...so the door ajar light does not come on when the pass. door is open.
crazy_canadian
Rattle-Mobile
Quebec
nice! so I'll try to clean it tomorrow with some WD-40 see if it change something.
oh and... Non, je suis jamais aller a Gatineau!
