Wider Tires?
JasonoftheRugar
Wisconsin
Did you have to do anything to prevent rubbing with that setup? Looks great and thinking it might be a good mod when my current tires are for R&R.
The rear was a slight problem. The tire rubbed on the inner plastic fender well. Used a die grinder. Fixed.
Sgtmeatsauce1
2013 SHO +pp
New Jersey
Wow awesome wax job, only car I saw looks like mine shiney, I use Collinite 476s. BTW what tint is that, that's my next expense
Sgtmeatsauce1
2013 SHO +pp
New Jersey
If stock 2013 pp no H&R springs, would I be able to run those 275 40 20's without rub, even on aggressive turn ins?
JasonoftheRugar
Wisconsin
The offset of the wheel will tell the truth. NO less than 30. Tint is 20%. Car never sees rain-only dust and bugs. I use Wizards mist and shine and a life long user of Race Glaze polish.
Sgtmeatsauce1
2013 SHO +pp
New Jersey
When I need tires I want to go up to the 275 40 20 size, they look fat.
I use Klasse 2 step in the Spring, then Collinite 476s as my go to wax, once a month or so during the 3 seasons. It is an outside car. I put a last wax on in fall, Collinite protector. Shiny as glass protected too. Yours looks great. Thanks for the info
Sgtmeatsauce1
2013 SHO +pp
New Jersey
So no problems with stock PP suspension, no H&R springs, car has new PP FRONT struts and PP rear shocks. Next up is the 275 40 20 tires, if no Problems reported with this set up......anyone,?
Jeff2017
I believe you may have some rubbing with the rear fender liners but that can be remedied with a steady hand and a dremel. 255's will fit with not issues.
Dewjr1985
Jacksonville fl
Don't be so ******* yourself David - you're not an idiot, I think the majority of people would agree the 245 are way to narrow for this car! I hate having my wheel sit "inside," the fender. Therefore, I think Jason has the perfect setup in my opinion! 275 all around meets the fender flush and looks OEM! That's my next mod!
How wide of a rim did yall go?
Lostneye
NY
2013 PP stock suspension here with 20x9.5 et35s and 275/40s no rubbing at all.
275s are too wide for stock wheels, 9" would work but 9.5" would be better
Since this thread was brought back to life I’ll add I did rub on the fender liner in the rear when the H&R springs were installed.
