Are you talking about the post you made in the "How do I" section?
If so, that is the section that was originally only for write-up type posts, rather than questions and answer type posts. The way I set the permissions up in that section all reply posts are/were moderated. That section has since moved away from what I had originally wanted for it so it might go away here before long.
That one post you just made is the only one that I can see that is moderated. If there are other sections you're having problems with as well please let me know.
By the way, the post I'm referring to above has since been moved to another section. I did approve
your post after moving it. You've made 2 post since the one that was put into moderation queue so I'm assuming you've found that all your posts aren't being moderated.
Edit: Right now you're replying to thread
Randomly Blowing IGN COIL fuse. Let's see if that one shows up. You better hurry up and let me know because otherwise I'm going to be following you all around the forum to see what's going on.
Edit Edit: Nope, that one's not in queue.
Rapping fingers on desk: Current Activity: Viewing Thread Randomly Blowing IGN COIL fuse
**Ahem! Ahem!**
You know...
some women are not known for their patience. You're lucky I'm
not your typical woman.
But it's ok....I'll sit here and continue to have a conversation with myself. Really, it's ok.
Well for heaven sakes...what is so interesting about that topic?
La-la-la-lalala-la-la..........
Ok-dokie then. I see how it is.
