Let me tell you what I do for a living.... winkDJ SHO:
I doubt that. The JBL amps are cleaner sounding (and sound decent too as the speakers are matched to the amplifier well), and have a "real" 20 watts per channel, unlike head units. It's physically inpossible to fit a great amplifier that can actually push some current to the speakers, in something the size of a head unit. There's not enough room. MOSFET sucks. unregulated power supplies make better sounding amplifiers IMHO. You might be able to get it "louder" from a nice Alpine unit, or whatever the case may be, but it sure isn't going to be clean at that volume. The auto-loudness and compression circuitry in the factory head unit is what kills the volume in such a nicely designed system (amps and main speakers - sub location and limited input signal to it could have been better IMO). I'll probably get flack for saying all this, but it's my opinion.yamahaSHO:
your Ford/JBL amps are crap. You should have used the HU's internal amp as it is most likely more powerful and cleaner.
Back on topic, I say try the ground loop isolator. It will most likely cure the whining problem.
I have even run tests... My Pioneer 50w x 4(22rms x 4) is much better than the factory amps. The factory amps are not that powerful to begin with, the signal to noise ratio is not the best either. The inputs are also matched to the output of the factory head unit. There is NO need to run an amp through another amp... The factory head unit is a "pre-amp"... I sends out low level singals.
Your sound will be louder and cleaner if you jut by-pass them amps... I have tried numerous ways to utilize the factory amps, even used potentiometer to bring the output levels from the HU down to factory specs... Still did not sound that great. I also got a hiss from the right rear speaker(even when stock)...
Actually, Metal Oxide Semi Field Effect Transistors are very good at what they do. Great power for the size and cool operation. If you want a really good amp, go with a Class A amp as it is very inefficient... I could go on, but how good does the signal to noise ratio have to be in an automobile when you got power wink ?
Also, have you opened up or even picked up the factory amps? There is not much in them...
But maybe you're right, seeing how everything Ford put into the car is "Top Notch" quality...
<small>[ February 10, 2004, 07:58 AM: Message edited by: yamahaSHO ]</small>
