bittertech
Starting next week, I start a new job that I'm pretty excited about, and requires a 500+ a week mile commute -- I've always been lucky enough to have lived within 10 miles of my work, so I learned to 'live with' a number of flaws in my car. I first got an SHO as my first car when I was 16. My dad has owned a 90 and a 91+, and when I decided to sell mine with 140k (90) on it my dad (220k) decided he wanted my engine.
Long story later, we finally get the engine back in 3 years later. Yeah. And then I total the car I had sold my SHO for. My dad has a new car, so I'm given the SHO with my old cars heart -- and proceeded to treat it like a beater. So many things were wrong with it, but it survived. It even got me across the country -- from Atlanta to Seattle and back (and on the return trip it was towing a 5x8 Uhaul!). I drove it for 3 months stuck in second gear (once again, living less than 10 miles from work helped).
But last week, faced with a 500 mile a week commute, I came to the realization -- as much as I've whined and moaned about the SHO, taken jabs by my friends for having a middle-age crisis car, etc, it has never left me stranded. Theres only one time I can think of that I had to call my folks to come pick me up when I was out with it, and I ended up fixing that (loose battery terminal) before they got there. The car (Albino Eeyore) has 249k miles on him, when we did the engine swap (engine has 160k on him now) we did most of the 60k service except the valve adjustment.
But with close to 250k on the frame, its time to start taking some care of the car. I realize that I'll never be able to get as nice a car for $2000, and with a little more TLC, I'll be able to drive this car till the wheels fall off.
So, I've been looking to invest in some upgrades, and have a few questions I was hoping to get some input on -- and for someone to be a voice of reason and tell me where to stop because I'm afraid I'm getting to be like a kid in a candy store here (though I think I'd have better luck asking the alcoholics at AA when I should stop drinking..) Mind you though alot of this comes from "I'm going to need to fix this anyway... but while I'm at it, I upgrade it, and for a little bit more money and work I can upgrade this and this too." Its a slippery slope.
So.. here's my list so far..
Job: Rear struts
While I'm there: Solid(polyurethane?) swaybar bushings, car is 90 with probably a 26mm swaybar that shouldn't need changing.
Parts needed: Rear Tokicos
Questions: I don't need to lower, so would aftermarket springs be worth it?
Job: Front Struts
While I'm there: Hoo boy
I. Solid Subframe Bushings
II. Tower Strut Brace
III. 96 Brake Upgrade
IV. Solid Swaybar Bushings
VI. With brake upgrade -- new wheel bearings
VII. Strut Bearings (are these cups?)
VIII. Tranny Drain Plug Install
IX. Replace all wheel studs
X. Change brake fluid (yes, 250k and its never been done. Nor has the MTL been changed.)
Questions:
1. What else should I be replacing while I've got the front suspension out? With 250k on the car, I think I can assume pretty much everything is worn.
2. What parts should I be ordering new in regards to the strut job? I mean, new struts is obvious, but I don't know (or have a vague idea) what the cups are.
3. With the 96 brake upgrade -- I plan on doing a junkyard run here in the next few weeks (hopefully I'll get a warm day) to pull off what I need -- I'm assuming I can use the knuckles (also, knuckles refer to the front while spindles refer to the rear, right? I saw them used interchangably and it threw me off for awhile) off a 94+ SLO, correct? And pick up the calipers off a 95(+?) Continental with FNB7(?) Stamped on it? We already have the brackets.
4. Once again, outside of lowering, should I be replacing the stock springs? I plan on installing Tokicos front and rear.
Yeah, I've got a bit of work ahead of me, hopefully it'll only take a week or two (working on the weekends) if I plan it right, get the parts I need before hand, and don't screw up too badly. I have to say this too -- When I was 17 (in 97), I used to read the SHOtimes mailing list back in the day, but it was often hard to get the right information in front of you when you needed it. Amazing what the SHO community has done in my 5 year absence, course I'm also alot more willing to take a wrench to my beast these days, so I'm probably just paying more attention.
Ohya, and I should mention that even though it's a 90 we do have 91 cheese slicers on it, so clearance and the brake upgrade shouldn't be a problem.
Job: Rear struts
Job: Front Struts
Questions:
