Where should RPMs sit on highway
92YamahaSHO
illinois
My rpm sits at about 28,000 at 65 is that normal? all other cars i've driven sit at about 2,000
ShadetreeSHOguy
Postwhore
Dallas, Ga
:ruhroh: WOW, AND YOUR ENGINE IS STILL IN ONE PIECE?! lol, just messing. mine at about 65 is at about 2300 rpms
GEORGE 1992
LONG ISLAND NY
I've learned here thaat the Ford Guages aren't too accurate. That being said, these cars do rev a little higher in fifth gear then most American cars. Hope that helps and keep her running.
Sho_Freak
^^ Awesome!
Iowa
for some reason my atx sits right at 2k at 61mph...and about 2400-2500rpm at 71........thats better than one of my friends mtx...........
yamahaSHO
E85 whore
Arkansas
That would be because the are geared totally different. ATX and MTX do not relate.
Sho_Freak
^^ Awesome!
Iowa
really...i thought the mtx 5th gear and atx o/d gear were the same ratio........ :confused: thanks for the info Jason! :bonk:
Axianator
I am a banana!
Roanoke, TX
Don't forget about the converter, fokker. Unlocked, the ATX will actually run at a slightly higher RPM in fourth than it's MTX counterpart would in fifth. ;)
yamahaSHO
E85 whore
Arkansas
Indeed :p
Shoaz
Studly dood
Scottsdale, AZ
In fourth gear in an MTX the tach and speedometer needles are always parallel. If you ever lose one you can tell the other this way in fourth.
Oddly enough, my FSVT is the same way, and it has six gears instead of five. Fourth gear and the tach and speedo needles are parallel.
Must be a Ford thang.
I believe the final drive on the ATX is 3.74 also. There is a 3.98 final drive gear and chain from a '96 Windstar tranny that will work as long as you know a good programmer.
Tire diameter = (mph x gear ratio x 336) / Rpm
Gear ratio = (rpm x tire diameter) / Mph x 336
Mph = (rpm x tire diameter) / Gear ratio x 336
Rpm = (mph x gear ratio x 336) / Tire diameter
anarchy04
Duluth, MN
That is because like alot of 6 speeds that I've seen they have a fifth that is .74 OD and sixth that is .67 OD or something like that, two overdrives.
That's nothing new.... My '91 Festiva has two overdrive ratios. :thumb:
