unseenmisfit
I think i found the starter which is under the car right under the oil filter. would the solenoid be on it or close to it or what? i think i need to replace this because when i turn my key it just clicks. battery is fine.
ok so the starter and solenoid works fine and the battery works as well so im guessin its the cables. how would i go about fixing this? are you saying that the whole cable needs to be covered or it wont work, even the ends of them?
would oil on the ground be a reason why it wont work?
