where do I find technical service bulletins ?
timmcleod
michigan
pls advise where I can find tsbs. recent post suggests there something out on brake issues.
thanks
tim
SHO U UP
SHO Guru
Virginia Beach, VA
thanks
tim
Hey Tim,
Take a look under the Maintenance & Troubleshooting section. There are two threads a few down the list in regards to brakes. There is TSB information on there bud.
SHOrod
Torrie Tuned
Cedar Rapids, IA
If you want full access to the TSBs, including the full text, you may need to subscribe to a service such as AlldataDIY.
-Rod
Bill Strobel
theamcguy
Fayetteville NC USA
For the Eco-SHO I list the following TSBs as being issued for brake problems
2010 Taurus TSB 09-26-10 Rear Brake Noise
2010 Taurus TSB 10-5-6 Front Brakes Intermittent Noise Built On or Before 1 Jan 2010
2010 Taurus TSB 10-7-2 Rear Brake Drag or Noise Built On or Before 14 Dec 2009
Let me know the issue and I'll post the TSB
timmcleod
michigan
front brake noise
could you post 10-5-6 for reference during my 2nd dealership visit, RE: front brake " grinding "
noise during aggressive braking ?
thanks
tim
classiccars
Ohio
This 10-5-6 TSB doesn't sound like much of a fix. Resurface the rotors and install new pads. I thought I heard there was a newer TSB out there dealing with this brake grinding noise problem. It may have been TSB 10-17-3. Does anyone know what the latest on fixing this problem is?
I'm not too fond on having my rotors resurfaced after 7k miles. What happens after another 7K miles went the brakes begin to pulsate because the rotors are warped and are too thin to resurface again? The dealer will say it needs new rotors and it is not covered under warranty because the brakes/rotors are a wear "Maintenance" items.
Is there a newer TSB fix out there that correctly repairs the problem by replacing the rotor, pads, and brackets with a upgraded style? If so what is the TSB # so I can have my Ford dealer do the work correctly the first time.
Thanks
classiccars
Ohio
Can someone post a link to the TSB 10-17-3 as a pdf file? I would like to walk into the service dept. with a hard copy in hand before they start this pony show.
SHOrod
Torrie Tuned
Cedar Rapids, IA
Generally TSB repairs are no charge for the customer if the affected components are covered under warranty. If the items are not still under warranty though, it's up to the dealer on if they want to cover it or not.
-Rod
