I bought a used but great shape driver side halfshaft but need a new c clip. I think I should also get a new 30mm hub nut. Anything else new I will need? Where can I order these parts? Autozone does not carry the clip I need frown
a circlip isnt needed. when the suspension is assembled, it holds the half shaft in place. the purpose of the circlip is to hold the halfshaft in the engine assembly while in transport to the manufacturer. its cheaper to leave em there than to pull the half shaft and take the clip off. same goes for engine hoist points (on the top of the motor). a new hubnut is recommended, as they are one time use locking nuts.LL-Cool-A:
I bought a used but great shape driver side halfshaft but need a new c clip. I think I should also get a new 30mm hub nut. Anything else new I will need? Where can I order these parts? Autozone does not carry the clip I need![]()
