This only happens when I have my heat on and I'm at idle for about 5 minutes. Here are the symptoms:
1. Car made buzzing/whining sound from front end area...buzzing noise was first time it happened this morning in Dunkin Donuts drive through...lasted for about 3 seconds.
2. When this happened there was a little bit of smoke from under my hood towards the front left of my car.
3. Exhaust was darker but nothing crazy.
4. When this happened I turned off my heat and noise went away, smoking stopped, and slightly darker exhaust went away also. I could put my heater back on at cruising speeds and symptoms would return only if I were to idle for 5 minutes again with heat on.
5. Car ran fine, did not overheat, engine still smooth upon acceleration and idle. (tach didn't move either)
6. This only happens when my heater is on for a while and I'll be idling somewhere for about 5 min.
Any ideas? Do I need a new heater core? Water pump?
Any help is appreciated as I want this fixed asap!
Thanks
~Alex
Thanks
~Alex
