TicoSHO
93 in Largo, FL
I would like my car to stop as well as it accels. I've looked into the 96 upgrade and it's too much right now. Is there a brand or type of brake pads and/or rotors that will improve performance with out breaking the bank?
K-Dawg said:To do any real brake upgrade, you'll have to change knuckles. After that, you can get loaded Gen III calipers for less than $50 a side and rotors for about $70. So you're looking at about $160 plus knuckles that you'd get at a junkyard to do the 96 upgrade.
Short of that, you can pick up some Performance Friction Carbon Metallic pads at Autozone and some cheap rotors to go with them. These will be fine for the street. Could also pick up some stainless lines for a better feel.
I have had the pad/rotor upgrade for a while, but I didn't see much change. I just added the s/s brake lines and the difference is amazing. The balance, feel and modulation is great. Makes for a much better street set-up.jedhead said:If you can't afford a size upgrade, get some very good pads like PFCM pads and new rotors. Follow the brake inprocedures so you will have an even deposit of the pad material on the rotors for maximum effectiveness. Keep in mind that once you use carbon metallic pads on the rotors and you switch to a different material, the brakes won't work well until the old material is worn off.
Procedure for bedding pads and seasoning rotors. I have followed these procedures and never had warped rotor problems on any of the brake systems.
http://baer.com/baer/news/img/Pad_Bedding_Street_Light_Track.pdf
http://baer.com/baer/news/img/Rotor_Seasoning_Street_Light_Track.pdf
This is also good reading:
http://www.shotimes.com/brakes/survey/brakes1.html
Bob
You can adjust the rear bias valve to increase the rear brake pressure. Or get bias valve plugs from Shonut, as long as the ABS works.93inLargoFL said:I would like my car to stop as well as it accels. I've looked into the 96 upgrade and it's too much right now. Is there a brand or type of brake pads and/or rotors that will improve performance with out breaking the bank?
