What the heck caused this?? Bent butterflies....
wood_e
The dude
Ames, IA
Ok guys here's an interesting one for you... my intake has never been completley dismantled before. I tackled the task today and found something really odd....
2 of the 3 butterflies on the plennum closest to the front of the car are BENT! All the rest of them are fine. What caused this? How can I remedy this? Should I carefully hammer them straight?
shopartsnw
SHO Medic
Sponsoring Vendor
Battle Ground, WA
I have seen that before in some of the cores we used to build the big bore butterflies. I don't know what caused it.
The stock butterfly plates are pretty soft, you should be able to bend it back with your fingers. Worst case, if you needed a new plate, let me know, I have about a billion stock plates from Kurt's last couple runs.
- Mike
That condition can be caused by a severely premature ignition of the mixture in the cylinder with the intake valves still open. In other words, a backfire. Incorrect routing of the spark plug wires is probably the simplest way to accomplish this. Remember Artesia? He created a case very similar except that his butterflys were so bent the secondaries wouldn't fully close or open.
wood_e
The dude
Ames, IA
yamahaSHO said:
Have you had any type of intake backfire?
Ever since I've owned the thing I doubt I have had a backfire. I dunno about the pervious owner... anyway good points! I never would've thought of backfire but that makes a lot of sense.
