What size nut is this?
sideSHO
East TN
Hey gang.
Missed something rather important on my clutch job.
I left the nut off the pinch bolt that holds the strut to the hub.
I went to Autozone and they could'nt tell me what size.So do you guys know?
Also
I've read that there is a circlip on the drivers side axel.I know I did'nt take one off,but I'm not sure if one was ever in there.How important is this circlip?
Could this cause the slight slack I have at highway speeds in the drivetrain?
Thanks for all the help.
Ishodu
If you are talking about the pinch bolt that holds the strut in there is no nut it is a threaded hole. Unless some one has drilled it all out then it could be about any size in that range.
