Racer X
SHO Pilot, Retired
As the topic states, what size drift should I use to remove and reinstall the roll/ tension/ spring pins in my stock MTX differential?
Why not run a tap and thread in some hardened steel screws? I bet they wont back out?
I'm sure this has been asked before but seems like good idea.
BE VERY CAREFUL!!! 1 Wrong move ='s SHO BOOM!
Change 1 roll pin at a time.
Drive the old roll pin out from the speedo gear side of the diff using a 5/32 drift punch. Be careful as you get real close to the speedo gear.
Drive the NEW roll pin from the opposite side of the diff with a 7/32 drift punch.
Measure the depth of the installed roll pins, to make sure they are centered with the pinion shafts.
Again be very careful, and change 1 at a time. If you use the wrong drift punch (too big) the diff will blow up.
Now is the perfect time to have the diff "reinforced"!!!
You said a 7/32 drift for install. If the replacement pins are 3/16, wouldn't a 7/32 be too large for the slight countersink? Or is the bore large enough to accomodate a 7/32 drift?
