What other mods needed with ported heads to get the codes cleared?
jimtash
nc
Check your ground at the center of the intake valley, as that controls the O2 sensor heaters, I had that issue where the CEL would come on and go out, and in the end it led me to that I had no ground for the heaters, causing the O2's to cool off, going lean, fixed that problem and my CEL went away
That's what it was. I looked closely in the valley and there they were, two loose ground wires. I bolted them down and no more codes.
I also used new intake bolts and did everything in sequence including the clamps. It runs good.
Thank you for your post. And I want to say thanks to everyone else as well.
Brad kirk
