What next???????????/
stangeater
Farm Boy
Okay, here's the story. I've been having a front end wobble between 40-50 mph. My first thought was that the wheels were out of balance or bent. Had the wheels balanced for $35........still wobbled. Okay, it's probably wheel bearings. Had the wheel bearings and brakes replaced for $300..........still wobbled. Okay, it's probably a front end alignment. Had the front end alligned for $40...........still wobbled. By now, I'm getting ticked at this MONEY PIT! I took my car to a local shop and had them check out all of my cv joints/shafts, and they all checked out okay. I don't know what to check next??? Any ideas? I still believe it has somthing to do with one of the front shafts. Any help would be greatly appreciated!:nut:
HoustinoJillian
name's JUSTIN
usa
can you be more specific on the wobble? is it the whole car or jsut the steering wheel? could it be something loose in the steering column?
stangeater
Farm Boy
Yeah, I know it's hard to discern things like "wobble" in a thread!:nut: It feels just like one of the front rims would be bent, that's the kind of wobble. It's definantly comming from the front end, and only between 40-50mph. By the way, I swapped wheels with my brother (he also has a sho) just to rule out the bent rim/broken tire cord, and my car still wobbled..........his drove fine. So, I'm back to step one.:nut: I really think I'm going to take it back to have my CV shafts replaced. It has to be them???????
jedhead
westminster,ca
When my half shafts went bad, it drove me nuts. I swapped virtually everything but the shafts. The symtoms were that I would get a vibration between 40 and 50 only when accelerating. I am slowing down or braking between 40 and 50 no vibration. No clicks while turning either.
Bob
stangeater
Farm Boy
Jedhead, thanks so much! That is when my car does the wobble......between 40-50 while accelerating only. I guess I should have mentioned that earlier. This makes me feel better about my assumption that it's the cv shafts! No clicks here either, I think that's because it's the inner joints that are bad. Thanks again.:thumb:
randy'sho
95 White MTX
High Point, NC
yeah stangeater, i would listen to your little brother when he told you that it was your cv's......ahhhhhhh what a rewarding feeling to be the younger brother and to be right!!!! hahaha...jk i hope that new cv's will fix it.....to all of you that are going what are you talking about, i am stangeater's brother, by the way my sho is faster.......both of them..........lol
