What is a good set of Wires/plugs to use?
SHO04093
Buxton,Maine
Hey guys I was getting ready to do the tune up and am getting the things I need to do the job and Plugs and wires are on the list was wondering what wire sets there are availble for aftermarket that are good and Plugs also coil packs? I have read threads that people have said that the stock wires are just as good if not better then aftermarket? not sure if that is True or False?? any good info would greatly be apreciated thank you again for your time.
SuperHO
Mental Patient
St. Joe, MI
From what I've been able to tell, unless you wanna dump the cash on a set of Motorcraft Wires (which are the best for the SHO), Taylors work quite well. As far as plugs, Advanced Auto has NGKs for around $2.99 a piece, and they've been working splendidly for me for about 10k miles...which is a long life in my car for some reason.
NWGRN94MTX
Vancouver, WA U.S.A.
plugs- Denso p/n PK16R11 or the original Motorcraft AGSP 32PP if you can find a set (discontinued)
Wires - AC Delco, original Mortorcraft's, I have heard reports back that Taylor's and Accel's work good.
sho'd
Git R' Done
ontario,canada
i use the ngk's and accell wires, they fit perfect and the wires cose me 120 canadian as apposed to the ford's 200.00, the wires i got at part source and the plugs at napa, they are ngk g-power platinum, as for the part number, i would have to see if i can find a empty spark plug box.
SASHO91
Zoom Zoom
San Antonio,TX
The P/N i got off their site is BKR5EGP for the the G-Power's, and BKR5EYA-11 for the V-Power. (which is what i had, and made more power with... :madflame: )
they have the G-powers listed @ 2.98 a plug, and the V-powers @ 1.77 a plug... hmmm.
SHO04093
Buxton,Maine
Where to Find Accel wires?? Part ##
I been looking for the Accel wires but i can not seem to find them? I went to there Site and there is no listing for the wires for The SHO???
1slickRED89
Guest
Toledo Ohio
Autolite makes plugs and wires. available at advance auto. AGSP32PP, the Ford service plug up till a few years ago, is identical to the autolite APP3924, except for the print color. there is a $1.25 per plug rebate on them as well.
what will NGK think of next. V-power and now G-power, when will the west catch up?!
Zeegs
Canada
I've been using E3 plugs (#e3.48), for the past 10000 km and i've seen an increase of at least 2mpg. But the plugs that were in when I got the car weren't in too good condition, I think they were bosh.
I just installed a set of the Autolite APP3924 plugs and was not really surprised to find that the plug boots did not fully seat against the valve covers. The Autolite plugs are about .5mm taller; enough to prevent the rectangular plug boot seal from pressing against the top surface of the valve cover. I added O-rings around the boot shaft where it meets the head portion to have some interference between the boot and the valve cover to prevent the ever present flying dust and debris from finding a home in the hard to clean plug wells. I added this post to this latest topic that turned up in a search of "Autolite APP3924."
yamahaSHO
E85 whore
Arkansas
I ran a set of 3923's (copper) with stock wires and they matched up fine. I'm not sure if they are any shorter than the stock replacements.
1slickRED89
Guest
Toledo Ohio
sdpatt said:
When I checked the prints I found the motorcraft AGSP32* heat range plugs had identical dimensions to the *3924. thats assuming they were made to print, a big assumption. I would imagine gasket crush may come into play comparing older plugs to new. the gaskets are directional too I found out. I trust you torqued them to 15 lb/ft?
I measured the Motocraft AGSP32PP plugs and the Autolite APP3924 plugs and found the insulator section to be about .5mm taller on the Autolite version. Side-by-side you could see the difference.
Ishodu
I checked it out as well the autolite APP3924s are a tad longer then the OEM Motorcraft. From looking at the design of both plugs most people would just assume they are the exact same plug. I did at first.
1slickRED89
Guest
Toledo Ohio
they are both the same on print, and have all the same part numbers for constituant parts. further, the 10 new samples I looked at this morning where Identical. comparing a new plug to an old one may be the tricky part.
keep in mind that if you install then reinstall a gasket seat plug it shrinks by .2mm because the gasket squishes more and more as it gets worked.
SHO Type U
AGSP 32FM is the replacement for these, they fit/work fine.
DemonNeno
SHOCAGO Freak
Skokie, IL
SHOtimes list had mentioned this point about the autolites back in '98. It was always thought out to be one of the same plugs, the autolite and motorcraft, but infact had different lengths.
Other then motorcraft, taylor, accel, and delco, i've heard fitment issues with wires. I just ordered a set of Taylers, that extra insulation sound pretty good to me!! $89.00 shipped! I thought Midwest SHO carried them, but couldn't find them on the SHObros page. Purchased 'em from Summit.
allbuti
Virginia
Is there any harm in mixing AGSP 32FM and AGSP 32PP, assuming you have some of each unused, but not 6 of the 32PPs ? Also I've never changed the spark plug wires and I've been using them for 14 years and 230K miles. If everything seems to be running fine, is there any reason to change them?
DemonNeno
SHOCAGO Freak
Skokie, IL
You can check to see if the wires are bad. With that many miles, i would advise to replace them due to the natural breakdown of the wires. As they age and their insulation weakens, you will lose ignition through the wires. If you would like to test them, fill a spray bottle with water and run the car. Mist the water above the wires to see if there is any current leaking through them. It's best to do this in a dark garage or at night. It'll be noticable if they are losing spark.
