What does this sensor do?
ACV1081
Member #187
IA US
I found my 91 to have this sensor unhooked and broken... I was getting no CE light, or unusual driving conditions. What does it do? It's found on the coolant line on the rear head. I think it's feeding the heater core? Just curious as I already swapped in a different one. :wave:
TIA,
Adam
That is the Cold Engine Lock Out switch. It keeps the heater fan from coming on until the coolant temps rises above 100F or so.
Sho-Driver
Peter Pan
The Garage.
Super Matty P said:
CTS maybe? (coolant temp sensor)
p.s. those headlights are great. Where did you get them?
That's known at the ECT (Engine Coolant Temperature sensor).
I believe the headlights are from an Impala.
Rockledge
Pluggin' away
Connecticut
Actually, I believe Paul is corrrect. The ECT and the cold engine lockout (CELO) switch do look somewhat similar, but from what I see in the pic, and from Adam's description of its location, I'd have to conclude also that its the CELO switch.
Sho-Driver
Peter Pan
The Garage.
You're right, Paul is correct. I quoted the previous post to denote the context. Please read into it more closely ;-) I was correcting his previous acronym.
ACV1081
Member #187
IA US
So, basically the sensor does nothing unless you've got the heater on? I am kind of having sub par performance with my a/c blower as it doesn't come out super strong like my mom's 95 when I put it on max a/c... any clue as to why that is?
Oh and yes the headlights are off an 00' impala. ;)
Thanks all,
Adam
Rockledge
Pluggin' away
Connecticut
Gotcha. ;)
