what does this mean?
19SHO90MTX
fo'sho
Dallas,TX
The other day I did a burn out but my car couldn't handle it. The throttle got stuck WIDE open (again) and went crazy!! The RPMs did a a full 360 and now it's under the little black stick instead of being over it? what happened there? Last time when it got stuck that meant the motor mount bolt couldn't handle the power. But why did the RPM's go crazy? And can the rpm thing be fixed! :omg:
RStalveyARFF
too many shos
Georgetown, MA
yes it can be fixed. Floor the car again and you should be all set. Check for either a sticking throttle cable, or I've found sometimes the bracket for the throttle cable bends and causes that sticking.
2L8V8_4sho
SHO Connoisseur
Washington DC
It doesn't matter anyway. If you keep doing burnouts and redlining your car you're not going to have it for very long.
F-22 Raptor SHO
7015 feet above Sea Level
1: check cable for stickyness
2: check throttle bracket for bendiness
3: check floor mat for stuckiness
Reset the tach by allowing car to warm up to operating temperature, then go out for a drive...in an open safe area, from a roll, mash the gas when you are in 1st and take the car to redline. Tach will reset when the car reaches about 6500 or so.
