What do you think ?
slipondajimmy
Massachusetts
OK well About 5 months ago I had a waterpump replaced in my 94atx. At that time my mechanic said my alternator was loud and probally should be replaced soon. I didnt bother until today. I replaced it and the so called alternator noise is still there. It sounds just like it did before the waterpump was replaced. What else would cause a whining noise in the general area of the water pump?
If needed I will take some audio of the noise in the morning .
SuperHO
Mental Patient
St. Joe, MI
Could be bearings in the timing belt tensioner....my 92's making a sound that rises and falls with the revs, and that's exactly the problem. I'm almost hesitant about fixing it, cuz I've had three people ask me if it was a supercharger..... :evilgrin:
slipondajimmy
Massachusetts
I have not checked that But I will do tommorow. Im ticked that I broke down and spent the money for a new alternator and it was not even the problem ...lol
SuperHO
Mental Patient
St. Joe, MI
eh...consider it preventive maintenence. You have to remember that not a lot of altenators can survive time spent at 7000rpms. Not good for ANY bearings, for that matter...but then, who can resist? :evilgrin:
slipondajimmy
Massachusetts
Well I did think of that. Like I said earlier I replaced the waterpump a few months back and had the timing belt done as well( didnt mention this) . The whining noise was also there before the work was done. I replaced the alt and serp belt yesterday.
So Thats where im having issues. These noises where here prior to having any work done. I would like to have someone take a look at it But the one thing I have noticed is you mention the word SHO in this area and mechanics run away from me ...lol. Nobody wants to touch the damn thing. I have goten pretty handy owning this car the past 2 years...hahaha
Any other suggestions would be helpful
qiksho
SHO Addict
Fargo, North Dakota
Take your surpentine belts back off and spin all the pulleys by hand. You should be able to hear/feal which one is bad. If you don't find an accessory pulley's with bad bearings then its time to check the timing belt tensioner. ;)
slipondajimmy
Massachusetts
OK well I did as mentioned above and it does appear that a idler pulley is no good. I removed it and if you spin it slowly it seems to click or stick in one spot . Is a bearing for this available somewhere?
slipondajimmy
Massachusetts
hmmm it would figure. Cant find a bearing anywhere. Ford wantsme to order the whole pulley at a cost of 135 dollars . and there is no local bearing shop anywhere. any ideas
slipondajimmy
Massachusetts
Ahh I got it. Im not sure that is the right one. 4-6 rib? Im looking for a bearing for the idler not tensioner. part number on the bearing is 35BD219DUK (NSK)
silversho89
Whatever
Around
Just for future reference, if you have a noise like you and lets say you think its the alternator. Take a broom stick and put it on the alternator with your ear to the other end. If you hear the same noise youve found your source.
But please be careful to not get it caught up in the rotating parts. Im sure that wouldn't be too fun.
This trick is useful for many things. ****, you can even stick it to the valve covers and here the cams hitting. Its kindve neat.
Rob
Ishodu
V6 ATX or MTX NSK Bearing for 4 and 6 rib tensioner pullies (requires installation) (yes, this is the right one, correct width etc) BD20-15DWA
slipondajimmy
Massachusetts
well I went over to jacks junk yard down the hwy from me and they had a idler in a banged up SHO ... 5 bucks what a steal . I still have a little bit of a whine but not as bad.
