Eric VerValin
PiMPSKiLLET
Ok... backstory... got a .17 amp draw on my battery, and am waiting on the alarm company to email me back as to the power consumption of the alarm system I have on the car now.
Anyway... my battery is getting on the lower end of the 'charged' scale as it sits in the car today, and I go out to start it, and it cranks really really slow.. tach keeps moving upwards slowly so I left it crank to see what it would do.. tach swept up past 4000.. then I figured I was heating up my starter, battery , and cables pretty good at that point, so I let off the starter.
Then I go to turn it again, and it seems as if the battery just got some extra juice, because the car is turning over twice as fast as it was before. Weird.. so I let it crank a few, mash the pedal to clear out the fuel, and let off the starter again.
The next time I turn the key, its faster than the other two times, pretty close to "normal" and she fires right up... but... my battery light was on.. until I blipped the throttle, then the interior electronics "pop" on like I just turned the key on....
I'm going to put some new cables on, and charge that battery up again... then see if I can't get it load tested or something... it's a 900amp, and only a year old.. shouldn't be bad, but who knows...
Isn't there a way that the "field" in the alternator or starter can leak ? Maybe its too early but I want to say there's a way voltage can leak out to ground thru an "electric motor".
This is the last of my little issues with this car, and I'd like to figure this out... thinking I might get under the hood, and clean up all the grounds again.. I wonder if my ECU ground might be bad... not really sure tho... feel like I've been over all the obvious stuff already..
