Weird Shaking (trans)
Mechanicsville MD
Ok..this problem just started the other day and kinda got worse. When im in 5th gear at hwy speed and let off the gas i get the normal slow down(like the gear is winding down) as you would think...BUT then it kinda feels like its letting loose like an automatic or something and it sounds like the trans is shaking back and forth. Im starting to think its a mount but i checked the motor mounts and they are fine. Do the trans mounts break?
1993MTXSHO
Its a Taurus...
Jersey
the trans mounts dont usually break but it is possible and has happened. Just pull the inner wheel well out of the drivers side and take a look at your trans mount.:thumb:
monkeyssho
Pennsylvania
Trans mount is more then likely bad as it starts to shake as you lift off the throttle. These are the same symptoms that mine had when it went out.
Adam
