weird brake question
moobypets
mooby
quebec
all my friend taurus 94 95 sho and 2002 gl and even my old red sho 90 all my brake pedal where hard
but on this car my 94 gl (with a sho engine )wich i have the new master 2 front mustang gt caliper
2 rear 90 sho brake disk setup and stainless steel line
but my pedal his never hard it alway mushy
wich his really getting on my nerve any brake setup or rotor pad combo i use im not gettign a good brake feel
and last time when i wanted to bleed the system the 2 front caliper bleed bolt where seized so i only flushed the rear wich seem to have helped
but im still lost and tired off that setting
a friend told me that when i push the brake we can see the whole assemble move and the booster too and that it must be my firewall that too thin making my pedal work so so ????
any pointer here ?
or it just a bad master from the start just my luck
Ishodu
I really have no idea what car your talking about the first line you say all the cars are firm including your 90 the next line your saying there soft.
Soft pedal is usually from a leak, air in the system, bad flex lines, or a MC issue.
kevinspann
Don't take my advice.
Richmond VA
We figured you'd be able to understand the other Canadian, Marcel.
Benoit, you need to find a way to fully bleed the system.
moobypets
mooby
quebec
it been bleed more then one time i was just wanting to flush the old oil since it about 80 000 and i have a tendency off replacing my fluid on regular interval
oh and i just re wrote sorry did not read before i posted this one
kevinspann
Richmond VA
I make fun of him on facebook sometimes - his posts are hard to read because English is his second language. Zach, when you first came here, your posts were just as easy to read.
The booster shouldn't be moving when you push the pedal. If it is significantly, that could be the issue. Is there fluid leaking from the back of the master cylinder, and down the booster?
kevinspann
Richmond VA
Good point Paul, Mustang calipers are best to be swapped left to right on the Taurus, due to the clocking of them.
Airborne
You will never get solid feel until the brakes are bled. Remove the broken/seized bleeder screws and replace with new ones. Air in the lines =spongy brakes.
moobypets
mooby
quebec
1 the system was bleed 4 time when everything was installed and yes all my bleeder are pointing up
got no oil leaking anywhere
if i remove the stuck bleeder i need to replace with new caliper ?
and ill try and get a video off my booster moovement when i brake
Did you try heat on the bleeder screw? If you snap it off you can drill it out with a left handed bit.
NoSlo
SHO Owner
Portland, OR
It is best to bleed the brakes with a clear vinyl hose on the bleeder that goes into a container for your old fluid with the end submerged. The hose has to be airtight around the bleeder screw before loosening. This will prevent air from getting sucked back into the caliper when you are pumping the brake pedal.
moobypets
mooby
quebec
i have ss line already lol one off my first mod on my gl
ill try that even do the 2 front master the bleeder are seized there
