We don't have a smog pump, do we??
Artesia
The Colony, TX
Hey, I was wondering...since we've got two cats on our system, and I didn't see any smog pump fittings on them...do we even HAVE a smog pump??
If so, which belt drives it, and how easy would it be to get a shorter belt and eliminate the smog pump out of the system or bypass it? What do you think the gains of it would be? Worth it? Maybe pick up a couple of ft-lbs of torque? Just curious.
- Brian C.
5576 Ragan Dr
The Colony, TX 75056
(972)625-2123
[email protected]
"We do not see things as they are...we see things as we are."
The SHO engine runs clean enough that it does not require a smog pump. Modern engine control technology has reduced the need for this system on most auto engines.
Scott
1991, 254K miles, glass hood, police grill, SVO shifter, Catz fogs,
6 disc CD, Class II hitch, Silver award at SHOklahoma Car Show
