Ok I have a fairly major water leak happening on the passenger side of my car. Water only leaks in when it rains or I wash the car (both by hand or a car wash). The water leaks in from here. If anyone needs more direct pictures/other angles I can snap some more this afternoon (after 4:30pm est). The picture is from just under the glove box. If i'm not mistaken, the front most piece of plastic is the housing through which the heat comes out when you run the heater for your feet. In the picture you can almost make out that it is still wet right at the joint and the left bolt is a little wet still. Any ideas on where to look would be great. Also I watched inside the enigine bay while running the water and didn't see any evidance that water was going through one of the rubber stoppers by the firewall. Thanks in advance for your help
<small>[ July 14, 2003, 01:00 PM: Message edited by: c_olcott ]</small>
