By the way this is the entire Plan for both the 5YR and 2YR.
“WHAT IS COVERED 5YR"
***Premium 2000 Plus***
Engine: All internally lubricated parts of engine, includes pistons, piston rings, piston pins, crankshaft and main bearings, connecting rods and rod bearings, camshaft and camshaft bearings, timing chain, timing gears, intake and exhaust valves, valve springs, guides, oil pump, push rods, rocker arms, hydraulic lifters and rocker arm shafts. The Engine Block and Cylinder Heads are also covered if mechanical failure was caused by the above-listed parts. Seals and gaskets are not covered except when required in connection with the repair or replacement of the above-specified parts.
Transmission: All internally lubricated parts of manual or automatic transmissions, including: torque converter, oil pump, valve body, governor, bands, drums, planetaries, sun gear and shell, sprag(s), shaft(s), bearings and related bushings, shift rail, forks, synchronizers, transmission case, bell housing, oil pan(s) and all internally lubricated parts of the 4X4 Transfer Case.
(Limits of liability are $5,000.00- $3,000.00 per Engine (aggregate) and $2,000.00 per Transmission (aggregate).
“What is covered 2YR”
Diamond Enhanced Component Coverage
Engine: Cylinder block, cylinder head(s) and all internal lubricated parts contained within the engine including pistons; piston rings; connecting rods; connecting rod bearings; crankshaft; crankshaft main and bearings; camshaft; camshaft bearings; cam followers; timing chain or belt; timing gears, guides, tensioners; rocker arms; rocker shafts; rocker bushings; cylinder head valves; valve guides; valve lifters; valve springs; valve seals; valve retainers; valve seats; push rods; water pump; oil pump and oil pump housing; harmonic balancer; oil pan; timing chain cover; intake and exhaust manifolds; valve covers; engine mounts; fuel pump; seals and gaskets; wrist pins; distributor drive gear; dip stick tube; balance shaft; balance shaft bearing; balance shaft drive bushing; valve locks and oil pump pickup.
Turbocharger/Supercharger: Turbocharger/Supercharger housing; turbo boost valve; turbo waste gate actuator; supercharger drive belt; bearing; bushing and all other internal parts and seals and gaskets. Coverage applies to factory installed units only.
Transmission (Automatic or Standard): The internal components of the automatic transmission or manual transmission. Drive chain, drive chain gears, carrier bearings, internal transaxle seal. The manual transmission case and automatic transmission case and torque converter are covered, if of internally lubricated parts. Flywheel/flex plate, vacuum modulator, electronic shift control unit, transmission cooler, transmission mounts, oil pan, seals and gaskets, shift linkage and shift bushing.
Transfer Case: Transfer case , drive chain, drive chain gears, planetary gears, shift rail forks, bearings, bushings, oil pump, output shaft, main shaft washers and all other internal lubricated parts, seals and gaskets.
Differential Assembly (Front and Rear): Differential housing, axles shaft, ring and pinion, bearings, bushings, washers, differential cover and all other internal parts contained within the differential assembly with seals and gaskets
Drive Axle (Front and Rear) Drive axle, constant velocity joints center support bearings, drive shaft and universal joints.
Steering: Internally lubricated parts contained within the steering box and pump housing, including control valves, internal oil control seals, bearings and shafts, steering box and pump housings if damaged by the failure of internally lubricated parts. All internal parts contained within the rack and pinion, gears, power steering hoses, steering knuckles, pitman arm, idler arm, tie rod ends, drag link, Steering dampeners, upper and lower steering column shaft and couplings, including internal tilt wheel mechanism, pinion gear housings, stepper motors, control valve and seals and gaskets.
Air Conditioner Condenser; compressor, compressor clutch and pulley; air-conditioning lines and hoses; evaporator; idler pulley and idler pulley bearing; hi/low compressor cut-off switch; expansion valve; pressure cycling switch and seals and gaskets. With the following parts are also covered if they are required in connection with a repair of a covered part named above: accumulator/receiver dryer; orifice tube; oil and refrigerant air-conditioning cooling fan motors, compressor pressure relief valve and ambient temperature sensor. Coverage applies to factory installed units only.
Brakes Master cylinder; vacuum assist booster, disc brake calipers, wheel cylinders, compensating valve, brake hydraulic lines and fittings, Hydraulic control unit and seals and gaskets. The following ABS parts are also covered: electronic control processor; wheel speed sensors; hydraulic pump/motor assembly; pressure modulator valve/isolation dump valve, accumulator, seals and gaskets, ABS master cylinder, hydro boost and electronic control processor.
Front and Rear Suspension (including rear steering): Upper and lower control arms, control arm shafts and bearings, bushings, torsion bars, mounts and bushings, upper and lower ball joints, strut bearing plates, radius arms and bushings, stabilizer bar, links and bushings, spindle and spindle support, wheel bearings, variable dampening suspension, compressor, control module, dampening actuator, solenoid, strut height sensor, mode selector switch, seals and gaskets, rear wheel steering, rear steering shaft and couplings, power cylinder and pump, electronic control unit/solenoid, phase control unit, stepper motor, steering box, control valve and rack and tie rod ends.
Electrical Alternator; voltage regulator; starter motor; starter solenoid and starter drive; engine compartment wiring harness; computerized timing control unit, EVP sensor, knock sensor, ignition switch, ignition switch lock cylinder, electronic ignition module, front and rear window wiper motor, headlamp switch, washer pump and switch, stop lamp switch, turn signal switch, heater/air conditioning blower speed switch, manual heater/air conditioning control head, horns, neutral safety switch, cooling sensor, clock, power window switches, power door lock switches, reverse indicator switches, starter drive, computerized timing control unit and crank angle sensor.
Enhanced Electrical: Automatic climate control programmer, electronic instrument cluster, mileage computer; distributor; ignition coil; electronic combination entry system (does not include transmitters and receivers for remote-control locks), cruise control module, transducer, servo and amplifier; powertrain control module; headlamp motors; power window motor; power seat motor; power mirror motor; power antenna motor/mast assembly; convertible top motor; power sunroof motor; power windows switch; cruise control engagement switch; power seat switch; power mirror motor switch; rear defogger switch; and power door lock actuator and switch, ignition coil, cooling fan and motor, fuel gauge, headlamp switch and voltage regulator.
Fuel Delivery: Fuel injection pump and injectors, vacuum pump, fuel tank, fuel tank sending unit, metal fuel delivery lines, pressure regulator, metering valve, idle air control and throttle position sensor.
Cooling: Engine cooling fan and motor, fan clutch, belt tensioner, radiator, heater core, thermostat, blower motor, hot water valve, water pump, overflow reservoir, radiator cap, thermostat housing, low engine coolant module, coolant probe and switch and sensor.
