Warranty on ATX Question
Status
Not open for further replies.
aaronsbiza
Sacramento, California
I got a quote from autowarranties.com for a 5yr/100,000 Low end warranty and a 2yr/24,000 being there best. I basicaly want this warranty for my tranny. When it fails I don't want to be stuck with the Fat Bill. I can get the 5yr for 695 and the 2yr cost about 1200. I was wondering if anyone could look over the items that are covered and tell me if I should just stick with the 5yr or if I will need the 2yr for a tranny failure...
5YR: Transmission: All internally lubricated parts of manual or automatic transmissions, including: torque converter, oil pump, valve body, governor, bands, drums, planetaries, sun gear and shell, sprag(s), shaft(s), bearings and related bushings, shift rail, forks, synchronizers, transmission case, bell housing, oil pan(s) and all internally lubricated parts of the 4X4 Transfer Case.
2YR: Transmission (Automatic or Standard): The internal components of the automatic transmission or manual transmission. Drive chain, drive chain gears, carrier bearings, internal transaxle seal. The manual transmission case and automatic transmission case and torque converter are covered, if of internally lubricated parts. Flywheel/flex plate, vacuum modulator, electronic shift control unit, transmission cooler, transmission mounts, oil pan, seals and gaskets, shift linkage and shift bushing.
aaronsbiza
By the way this is the entire Plan for both the 5YR and 2YR.
“WHAT IS COVERED 5YR"
***Premium 2000 Plus***
Engine: All internally lubricated parts of engine, includes pistons, piston rings, piston pins, crankshaft and main bearings, connecting rods and rod bearings, camshaft and camshaft bearings, timing chain, timing gears, intake and exhaust valves, valve springs, guides, oil pump, push rods, rocker arms, hydraulic lifters and rocker arm shafts. The Engine Block and Cylinder Heads are also covered if mechanical failure was caused by the above-listed parts. Seals and gaskets are not covered except when required in connection with the repair or replacement of the above-specified parts.
(Limits of liability are $5,000.00- $3,000.00 per Engine (aggregate) and $2,000.00 per Transmission (aggregate).
“What is covered 2YR”
Diamond Enhanced Component Coverage
Engine: Cylinder block, cylinder head(s) and all internal lubricated parts contained within the engine including pistons; piston rings; connecting rods; connecting rod bearings; crankshaft; crankshaft main and bearings; camshaft; camshaft bearings; cam followers; timing chain or belt; timing gears, guides, tensioners; rocker arms; rocker shafts; rocker bushings; cylinder head valves; valve guides; valve lifters; valve springs; valve seals; valve retainers; valve seats; push rods; water pump; oil pump and oil pump housing; harmonic balancer; oil pan; timing chain cover; intake and exhaust manifolds; valve covers; engine mounts; fuel pump; seals and gaskets; wrist pins; distributor drive gear; dip stick tube; balance shaft; balance shaft bearing; balance shaft drive bushing; valve locks and oil pump pickup.
Turbocharger/Supercharger: Turbocharger/Supercharger housing; turbo boost valve; turbo waste gate actuator; supercharger drive belt; bearing; bushing and all other internal parts and seals and gaskets. Coverage applies to factory installed units only.
Transfer Case: Transfer case , drive chain, drive chain gears, planetary gears, shift rail forks, bearings, bushings, oil pump, output shaft, main shaft washers and all other internal lubricated parts, seals and gaskets.
Differential Assembly (Front and Rear): Differential housing, axles shaft, ring and pinion, bearings, bushings, washers, differential cover and all other internal parts contained within the differential assembly with seals and gaskets
Drive Axle (Front and Rear) Drive axle, constant velocity joints center support bearings, drive shaft and universal joints.
Steering: Internally lubricated parts contained within the steering box and pump housing, including control valves, internal oil control seals, bearings and shafts, steering box and pump housings if damaged by the failure of internally lubricated parts. All internal parts contained within the rack and pinion, gears, power steering hoses, steering knuckles, pitman arm, idler arm, tie rod ends, drag link, Steering dampeners, upper and lower steering column shaft and couplings, including internal tilt wheel mechanism, pinion gear housings, stepper motors, control valve and seals and gaskets.
Air Conditioner Condenser; compressor, compressor clutch and pulley; air-conditioning lines and hoses; evaporator; idler pulley and idler pulley bearing; hi/low compressor cut-off switch; expansion valve; pressure cycling switch and seals and gaskets. With the following parts are also covered if they are required in connection with a repair of a covered part named above: accumulator/receiver dryer; orifice tube; oil and refrigerant air-conditioning cooling fan motors, compressor pressure relief valve and ambient temperature sensor. Coverage applies to factory installed units only.
Brakes Master cylinder; vacuum assist booster, disc brake calipers, wheel cylinders, compensating valve, brake hydraulic lines and fittings, Hydraulic control unit and seals and gaskets. The following ABS parts are also covered: electronic control processor; wheel speed sensors; hydraulic pump/motor assembly; pressure modulator valve/isolation dump valve, accumulator, seals and gaskets, ABS master cylinder, hydro boost and electronic control processor.
Front and Rear Suspension (including rear steering): Upper and lower control arms, control arm shafts and bearings, bushings, torsion bars, mounts and bushings, upper and lower ball joints, strut bearing plates, radius arms and bushings, stabilizer bar, links and bushings, spindle and spindle support, wheel bearings, variable dampening suspension, compressor, control module, dampening actuator, solenoid, strut height sensor, mode selector switch, seals and gaskets, rear wheel steering, rear steering shaft and couplings, power cylinder and pump, electronic control unit/solenoid, phase control unit, stepper motor, steering box, control valve and rack and tie rod ends.
Electrical Alternator; voltage regulator; starter motor; starter solenoid and starter drive; engine compartment wiring harness; computerized timing control unit, EVP sensor, knock sensor, ignition switch, ignition switch lock cylinder, electronic ignition module, front and rear window wiper motor, headlamp switch, washer pump and switch, stop lamp switch, turn signal switch, heater/air conditioning blower speed switch, manual heater/air conditioning control head, horns, neutral safety switch, cooling sensor, clock, power window switches, power door lock switches, reverse indicator switches, starter drive, computerized timing control unit and crank angle sensor.
Enhanced Electrical: Automatic climate control programmer, electronic instrument cluster, mileage computer; distributor; ignition coil; electronic combination entry system (does not include transmitters and receivers for remote-control locks), cruise control module, transducer, servo and amplifier; powertrain control module; headlamp motors; power window motor; power seat motor; power mirror motor; power antenna motor/mast assembly; convertible top motor; power sunroof motor; power windows switch; cruise control engagement switch; power seat switch; power mirror motor switch; rear defogger switch; and power door lock actuator and switch, ignition coil, cooling fan and motor, fuel gauge, headlamp switch and voltage regulator.
Fuel Delivery: Fuel injection pump and injectors, vacuum pump, fuel tank, fuel tank sending unit, metal fuel delivery lines, pressure regulator, metering valve, idle air control and throttle position sensor.
Cooling: Engine cooling fan and motor, fan clutch, belt tensioner, radiator, heater core, thermostat, blower motor, hot water valve, water pump, overflow reservoir, radiator cap, thermostat housing, low engine coolant module, coolant probe and switch and sensor.
Mr Anonymous
Tire Wall
Well, right off the bat I see that they limit the transmission payout to $2000, which means anything over that you're going to be paying out of your pocket anyway. Figure about $2500-$3000 parts and labor from a Ford dealer. They would probably be happy to send you to MAACO and have it come in under $2K, but you'll be back over and over again trying to get it right.
I also don't know that a catastrophic engine failure (which rarely happens in the V6 SHO's, but also isn't unheard of) would be repairable for under $3000.
You might want to keep shopping around for a warranty with higher limits...
aaronsbiza
Well I don't care so much for the Engine blowing I am sure it won't, I would just like to know if the less exspensive warranty will cover the normal issues with the 95ATX transmission. If not I think that the More exspensive warranty with no limit on coverage, may be a better choice in that it covers a lot of other small things like the fuel pump, alternator, starter, and other little things that can add up. I'm just looking for any opinions I can get. Thank you.
metallicasho
Spring Hill, FL
I was looking at that same warranty. For a 95ATX I am thinking about buying. It seems like a good deal to me. The Better Business Bureau gives this company a satisfactory record. If your tranny goes you will save yourself at least 1300 bucks. Over 5 years or 100k miles the transmission will most likely need to be rebuilt.
<small>[ March 04, 2003, 10:02 PM: Message edited by: metallicasho ]</small>
ViPER1313
Ijamsville, MD
What stops you from buying a car for $250 that needs a ton of work, spending the money on one of these warranties and getting the car repaired for cheap?
SuperHO
Mental Patient
St. Joe, MI
Hey!! Looks like a quick fix for the MTX guys who keep blowing diff pins, too.....but then, for pretty much the same price, you could get a Quaife and install......
shonole
One Star!
Thomasville, GA
I don't know the answer to that one, but what I wanna know is what would it take to stop you from commenting on 2 YEAR OLD threads?! :dig: :nut:
SHO#7
Cincinnati
Being in the automotive repair business, let me help you a little on this. When you buy a warranty on the internet and they do not need to come and look at your car first. Buyer beware. If it were just that easy. Most of those warrantys, ( IF you can get them to cover anything ) will decide to replace with use parts instead or new or reman ( it is their choice, not yours ). Also there is a disclaimer that floats around that will state a couple of things. Sometimes it is that the warranty will not pay out more than you paid for the contract. Or the warranty will not pay out more that black book value for your car. It is a very tricky game. I have run into at least 10 that would decline or screw their customer in one way or another at my shop for a transmission rebuild. I had one, that I prepped the guy for the worst and that warranty really stood up and did a great job. But I do not remember who they were.
Alot of warrantys that are sold when you buy the car are decent. A few are not. But almost all of the internet warranties are crap.
Just my $0.02 But please listen. I have to break it to people like you every day.
Mike
SuperHO
Mental Patient
St. Joe, MI
Pshaw! Who cares? it's info, man!
truth be told, that thread might've been around on this forum for longer than I have......
Status
