Warranty and Stage Tunes
MN
Well I think I've on the verge of pulling the trigger on Livernois...gonna wait till tonight and think it over. I mean first off these tunes seem to be pretty safe as is...lots of people running them on here with zero problems correct? This pertains to the Livernois tunes...seen other tunes and blown trannies etc. But Livernois seems to have a good track record.
And even with the tune...things like electronics etc will all still be covered obviously. The only thing that would be in doubt is burnt up internals or Catastrophic transmission failure which (crossing fingers) is unlikely. Even if it does happen...there seems to be a decent chance they'd just fix it. She has a heavy foot but doesn't beat the snot out of it. I think it'd be a safe move overall.
One aspect I'm kind of nervous about is I have no ways to monitor A/F, Boost, Timing, or KR. I mean I know these tunes are supposed to safe but it makes me a little wary. Are you other tune users running with no ways to watch these parameters?
Does the SCT have software to read live data from the serial port like the diablosport does? If so this would be of great help because I could just do a quick recording session with the laptop to ensure everything is ok. This might be a better question for Rick though...
thePUNISHER
ford tranny man
CT
The only time I look for aftermarket performance items is if the car comes in for a catastrophic failure. If your car comes in for common issues, TSBs, etc I could care less because I know it's an issue.
If you car comes in with pistons melted etc I contact engineering and let them proceed with the steps they require. Sometimes it is just questions about obvious mods and sometimes it is uploading info from the IDS.
I know of no way to check for a tune on the IDS. I know sometimes they will set codes if they are still loaded in the PCM or the IDS will not connect sometimes if they are loaded in.
I do know engineering will have us send uploads to them if they suspect tunes but I don't know for sure if it can ghost read old tunes.
Some techs say they can see if a car was tuned before with the IDS. If that's the case pm me and tell me how because in the 20 years with Ford I don't know how.
Hope this helps
Agreed!
EcoBrick Bob
Clear Lake, IA Naples, Fl
SCT Tuner comes with access to SCT Livelink 6.5 Logging software that allows you to log thru a laptop. Works great. :angelnot::sun: You download the LiveLink software from SCT website.:thankyou:
MN
Nice I think this just sealed the deal. Gonna order this up first thing in the morning. :) Now to decide on what stage I want.
Fishrising
New England
If ordering Livernois, and have access to 93 (or 94) octane, I'd go straight to stage 4+. Your going to end up there eventually anyways...
typhoon5000
Ferd Enganear
Shelby, MI
Glad you have cash to burn on that extended warranty.
I don't have any complaints with Livernois, but Ford has really been cracking down on warranty repairs due to aftermarket modifications and I wish you the best of luck, but I see it as just taking all of the cash you put down on that ext warranty and throwing it out of the window.
Scrming
Saginaw
Yep... i tried to resist... but was only a matter of a week or two before I had Rick send me the 4+.... 4+ simple ROCKS!
Scrming
Saginaw
can always cancel the extended warranty and get a prorated refund... and of course while Ford may not cover your powertrain, there is still a LOT of EXPENSIVE things outside of the powertrain that can go wrong that would be covered (depending on which extended warranty you opted for).
vernonator
'12 SHO
Iowa
Exactly - I have the extd warranty, and got it mostly for all the non-engine/drivetrain items. This car is CHOCH full of electronics that will be expensive to repair - what is the cost of the Nav unit to replace? Yes a tune MAY (again MAY) result in a denial of a engine/drivetrain failure - but has a livernois tuned car had that happen?
Come this spring I will be ordering a Livernois tune, warranty be damned. My only problem is the availability of 93 octane fuel here - its nowhere to be found. Highest I can get is 91 :frown:
MN
Like the others stated, it will only pertain to drivetrain. And I think this tune is proven to be safe being that it's been out for years now.
But do you think if a window motor goes out or my navigation quits working they'll deny because they suspect a tune?
Also as stated multiple times, they can see a flash...but disconnecting the battery shows up as a flash as well. So definitely up in the air...but it's definely a risk.
typhoon5000
Ferd Enganear
Shelby, MI
I see. I guess that makes sense. When I think of a warranty I mainly think of powertrain since that's typically the most expensive stuff, yes the nav and other electronics can be expensive too, but not as much as a motor or trans. With my truck, all I have is powertrain warranty left until 100K (at 84K now). I also didn't know that the ext warranty was refundable. Thanks for bringing that to my attention.
Well, I wish you the best of luck then.
:snicker:It should be a $1,000. bill burning!:laugh_ti:
Don't make me copy and paste it 1000x Bob! :p
black99lightnin
I am Legend
Louisiana
I would go with the tune from Livernois. I've been happy and lots of people are having very good results.
As for your extended warranty, if you've got the touchscreen radio/nav/hvac, price it and decide if you want to keep your extended warranty. I write service at a MB dealer, there is no way I'd own a Benz without warranty. Same with these new Fords and all their tech. It's pricey.
MN
Yeah agreed! We do have nav and every other option you can get on these so the warranty is a must.
shobroooo
