VSS and ACT sensor locations ?
93_SHO_off
Kingston,MI
I was wondering if someone could inform me of the location of the vehicle speed sensor and the air charge temp sensor on my 93 atx :shrug: ? thanks for any input.
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
The ACT is located in the side of the airbox's lower portion. If you remove the lid and filter it sticks into the side by the engine. Should have a little orange tip.
The VSS on an ATX is mounted right on the transmission and is apparently one of the hardest sensors on the SHO to change. It is in between the firewall and the transmission on the driver's side of the car.
Ishodu
The air charge temp sensor is in the air box just below the filter, remove the air filter and you will see it inside the box. As for the VSS follow the speedo cable down until it meets the tranny and you will find the VSS there with a plug on it.
93_SHO_off
Kingston,MI
Thanks guys, that should help. but are there any suggestions you might have to make changing that vss a little easier.
projectSHO89
SHOless In St L
Pay someone else to do it and keep your sanity.
Steve
