adidas_kn
LOWSHO
Okay so I'm back at the SHO build up after a long wait for some parts and I have a question. I am looking at Dougs' FPS kit because of the ease of install and removal, the look, and the design. My engine is a 3.2L 8.5:1 complete rebuild with stock heads as of right now and all the other goodies. I am looking to be in the 400-500whp range depending on boost levels and available gas. Now, Dougs' kit comes with the tried and true Vortech V2SQ head unit. What can it handle and at what boost level should I look to need intercooling with my L/C engine? I want at least 15#'s and max of 20#'s to keep the transmission parts in the transmission(cryo'ed gears, shafts and all new components with a Quaife and new half shafts will be installed when the driveline goes back in along with a very capable Southbend DXD 6 puck clutch).
When does the boost come on and will it handle my desired boost levels? I was thinking of using the newer Boost cooler system that inject a water/Methanol(wiper fluid) mix into the boost pipe to keep detonation at bay under the higher boost levels. Will the T trim be better suited for what I am looking to run?
Hook it up guys. I will wait till I get back to the states to fab up my turbo kit to my specs. I don't trust the local to help with piping fab.
