Very loose door opening handle.
tery
Silvia survived the purge- summer car
minnesnowta
Can someone tell me which part needs to be replaced to make this inside door handle tight again, It flops too much for my liking... see vid if you have a sec,
tks,
Terry
mrecoolgar
SHO NUP
Hershey-PA
There is a tension spring in the handle assembly that has failed.
The handle is easy enough to replace after removing the door handle.
I may have a good one.
tery
minnesnowta
Hey Kevin, THank you again, I really don't like the way it flops around. Let me know when you get a minute and/or...is that spring something that be replaced with another spring or...stretch the spring so that it is tighter???
the good news is that is the same part that all the Taurii had, so you can find good ones easily at the jy.
Satchmoz
